Olympus Stylus 725 SW Lens Replacement
  1. Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: step 1, image 1 of 3 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: step 1, image 2 of 3 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: step 1, image 3 of 3
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  2. Olympus Stylus 725 SW Lens Replacement: step 2, image 1 of 2 Olympus Stylus 725 SW Lens Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
  3. Olympus Stylus 725 SW Lens Replacement, Front Panel: step 3, image 1 of 3 Olympus Stylus 725 SW Lens Replacement, Front Panel: step 3, image 2 of 3 Olympus Stylus 725 SW Lens Replacement, Front Panel: step 3, image 3 of 3
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
  4. Olympus Stylus 725 SW Lens Replacement, Side Panels: step 4, image 1 of 3 Olympus Stylus 725 SW Lens Replacement, Side Panels: step 4, image 2 of 3 Olympus Stylus 725 SW Lens Replacement, Side Panels: step 4, image 3 of 3
    • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
  5. Olympus Stylus 725 SW Lens Replacement: step 5, image 1 of 3 Olympus Stylus 725 SW Lens Replacement: step 5, image 2 of 3 Olympus Stylus 725 SW Lens Replacement: step 5, image 3 of 3
    • After removing all four of the screws, pry the side covers off of the camera.
  6. Olympus Stylus 725 SW Lens Replacement, Lens: step 6, image 1 of 3 Olympus Stylus 725 SW Lens Replacement, Lens: step 6, image 2 of 3 Olympus Stylus 725 SW Lens Replacement, Lens: step 6, image 3 of 3
    • Unscrew four 2mm long screws using the #00 Phillips screwdriver.
  7. Olympus Stylus 725 SW Lens Replacement: step 7, image 1 of 3 Olympus Stylus 725 SW Lens Replacement: step 7, image 2 of 3 Olympus Stylus 725 SW Lens Replacement: step 7, image 3 of 3
    Buy
    • Remove four metal tabs from corners where the 2mm long screws were attached using tweezers.
  8. Olympus Stylus 725 SW Lens Replacement: step 8, image 1 of 2 Olympus Stylus 725 SW Lens Replacement: step 8, image 2 of 2
    • Remove the viewfinder lens using a prying device.
    • There will be two ribbons attached to the viewfinder. Remove the ribbons by sliding them off the viewfinder with your thumb.
Bobby Hodges
49 Reputation
6 Guides authored
Cal Poly, Team 33-71, Johann Spring 2010 Member of Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 4,467
