Olympus Stylus 760 Case Replacement
  1. Olympus Stylus 760 Case Replacement, Case: step 1, image 1 of 1
    • Remove the 2 screws from the bottom of the camera
  2. Olympus Stylus 760 Case Replacement: step 2, image 1 of 1
    • Remove the screw from the right side of the camera.
  3. Olympus Stylus 760 Case Replacement: step 3, image 1 of 1
    • Remove the two screws from the left side of the camera
  4. Olympus Stylus 760 Case Replacement: step 4, image 1 of 3 Olympus Stylus 760 Case Replacement: step 4, image 2 of 3 Olympus Stylus 760 Case Replacement: step 4, image 3 of 3
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  5. Olympus Stylus 760 Case Replacement: step 5, image 1 of 2 Olympus Stylus 760 Case Replacement: step 5, image 2 of 2
    • Pull the silver bracket and buttons off of the camera
  6. Olympus Stylus 760 Case Replacement: step 6, image 1 of 3 Olympus Stylus 760 Case Replacement: step 6, image 2 of 3 Olympus Stylus 760 Case Replacement: step 6, image 3 of 3
    • Remove the 2 screws on the right side of the camera.
    • Remove the 2 screws on the left side of the camera.
    • Circuit ribbon is attached at the top-left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  7. Olympus Stylus 760 Case Replacement: step 7, image 1 of 1
    • Flip up clip on circuit ribbon, carefully
    • Detach the ribbon from the rear to the front and pull it out, gently.
  8. Olympus Stylus 760 Case Replacement: step 8, image 1 of 1
    • You will be left with four major pieces
Tracy Donovan
13 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 620
