Olympus Stylus 760 LCD Screen Replacement
  1. Olympus Stylus 760 LCD Screen Replacement, Battery door: step 1, image 1 of 1
    • Slide the door located on the bottom of the camera in an outward direction
  2. Olympus Stylus 760 LCD Screen Replacement, Release: step 2, image 1 of 1
    • Pull back on the red release tab located on the left side of the battery.
  3. Olympus Stylus 760 LCD Screen Replacement, Replacement: step 3, image 1 of 1
    • Slide battery out of camera
  4. Olympus Stylus 760 LCD Screen Replacement, LCD Screen: step 4, image 1 of 1
    • Remove the 2 screws from the bottom of the camera
  5. Olympus Stylus 760 LCD Screen Replacement: step 5, image 1 of 1
    • Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
  6. Olympus Stylus 760 LCD Screen Replacement: step 6, image 1 of 1
    • Remove the 2 screws from the left side of the camera
  7. Olympus Stylus 760 LCD Screen Replacement: step 7, image 1 of 3 Olympus Stylus 760 LCD Screen Replacement: step 7, image 2 of 3 Olympus Stylus 760 LCD Screen Replacement: step 7, image 3 of 3
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  8. Olympus Stylus 760 LCD Screen Replacement: step 8, image 1 of 2 Olympus Stylus 760 LCD Screen Replacement: step 8, image 2 of 2
    • Pull the silver bracket off of the camera
  9. Olympus Stylus 760 LCD Screen Replacement: step 9, image 1 of 3 Olympus Stylus 760 LCD Screen Replacement: step 9, image 2 of 3 Olympus Stylus 760 LCD Screen Replacement: step 9, image 3 of 3
    • Remove the 4 screws on the inner face of the camera.
    • Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  10. Olympus Stylus 760 LCD Screen Replacement: step 10, image 1 of 1
    • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  11. Olympus Stylus 760 LCD Screen Replacement: step 11, image 1 of 2 Olympus Stylus 760 LCD Screen Replacement: step 11, image 2 of 2
    • Remove 4 screws holding the LCD screen in place.
    • Be cautious of the brackets that come loose when you remove the 3 screws on the right side of the camera
    • LCD Screen is attached to 2 ribbon wires
  12. Olympus Stylus 760 LCD Screen Replacement: step 12, image 1 of 2 Olympus Stylus 760 LCD Screen Replacement: step 12, image 2 of 2
    • Pull up on the small ribbon wire to disconnect it from the circuit board
    • Flip the little black clip up to remove the larger ribbon wire from the circuit board.
  13. Olympus Stylus 760 LCD Screen Replacement: step 13, image 1 of 1
    • Using a plastic separating tool, remove the LCD screen from the plastic casing.
Ryan Cosgrove
39 Reputation
1 Guide authored
One Comment
from where i can get repaired u760 camera
tahir zafar - Reply
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 33
All Time: 1,570
