Olympus Stylus Tough-8010 Side Panel Replacement
  1. Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: step 1, image 1 of 3 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: step 1, image 2 of 3 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: step 1, image 3 of 3
    • Remove the three screws (3.2mm) from the front panel using a T-6 screwdriver.
    • Take off the smaller front panel cover.
    • Carefully remove the larger front cover.
  2. Olympus Stylus Tough-8010 Side Panel Replacement: step 2, image 1 of 3 Olympus Stylus Tough-8010 Side Panel Replacement: step 2, image 2 of 3 Olympus Stylus Tough-8010 Side Panel Replacement: step 2, image 3 of 3
    • Remove the top two screws (4.1mm) using a #000 Phillips head screwdriver.
    • Remove the two screws (7.9mm) near the control pad. Set metal connector aside.
    • Remove the side panel casing.
  3. Olympus Stylus Tough-8010 Side Panel Replacement: step 3, image 1 of 3 Olympus Stylus Tough-8010 Side Panel Replacement: step 3, image 2 of 3 Olympus Stylus Tough-8010 Side Panel Replacement: step 3, image 3 of 3
    • Using a #000 Philips head screwdriver, remove the two screws (4.1mm) on the right side of the camera.
    • Remove the two screws (4.1mm) from the bottom of the camera.
    • Remove the single screw (3.2mm) from the front of the camera.
  4. Olympus Stylus Tough-8010 Side Panel Replacement: step 4, image 1 of 2 Olympus Stylus Tough-8010 Side Panel Replacement: step 4, image 2 of 2
    • Carefully remove the front panel piece.
    • Remove the screw (7.9mm) from the bottom left hand corner using a #000 Phillips head screwdriver.
  5. Olympus Stylus Tough-8010 Side Panel Replacement: step 5, image 1 of 3 Olympus Stylus Tough-8010 Side Panel Replacement: step 5, image 2 of 3 Olympus Stylus Tough-8010 Side Panel Replacement: step 5, image 3 of 3
    • Slightly bend the metal that is covering the side panel axle.
    • Using a paperclip, completely push out the metal bar that holds the side panel to the camera.
    • Remove the side panel door.
James G Payne
225 Reputation
2 Guides authored
Baylor, Team 7-15, Williams Spring 2015 Member of Baylor, Team 7-15, Williams Spring 2015
BU-WILLIAMS-S15S7G15
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 362
