Olympus VR-350 Front Plate Replacement
  1. Olympus VR-350 Front Plate Replacement, Front Plate: step 1, image 1 of 2 Olympus VR-350 Front Plate Replacement, Front Plate: step 1, image 2 of 2
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Front Plate Replacement: step 2, image 1 of 1
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Front Plate Replacement: step 3, image 1 of 3 Olympus VR-350 Front Plate Replacement: step 3, image 2 of 3 Olympus VR-350 Front Plate Replacement: step 3, image 3 of 3
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
Adri
456 Reputation
3 Guides authored
USF Tampa, Team 1-3, Leahy Winter 2015 Member of USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 461
