Olympus VR-350 Power Button Replacement
  1. Olympus VR-350 Power Button Replacement, Front Plate: step 1, image 1 of 2 Olympus VR-350 Power Button Replacement, Front Plate: step 1, image 2 of 2
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Power Button Replacement: step 2, image 1 of 1
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Power Button Replacement: step 3, image 1 of 3 Olympus VR-350 Power Button Replacement: step 3, image 2 of 3 Olympus VR-350 Power Button Replacement: step 3, image 3 of 3
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 Power Button Replacement, Back Plate: step 4, image 1 of 2 Olympus VR-350 Power Button Replacement, Back Plate: step 4, image 2 of 2
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
  5. Olympus VR-350 Power Button Replacement, Power Button: step 5, image 1 of 2 Olympus VR-350 Power Button Replacement, Power Button: step 5, image 2 of 2
    • Remove the silver panel from the top of the camera.
  6. Olympus VR-350 Power Button Replacement: step 6, image 1 of 1
    • Flip the silver panel over. The power button is the smaller button covered by a metal backing.
  7. Olympus VR-350 Power Button Replacement: step 7, image 1 of 1
    • Pull the metal backing away from the silver panel.
  8. Olympus VR-350 Power Button Replacement: step 8, image 1 of 1
    • Push the power button down and out of the silver panel with your finger.
2 other people completed this guide.
Adri
456 Reputation
3 Guides authored
USF Tampa, Team 1-3, Leahy Winter 2015 Member of USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 27
All Time: 1,398
