Omaker M4 Battery Replacement
  1. Omaker M4 Battery Replacement, Back Case: step 1, image 1 of 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Battery Replacement: step 2, image 1 of 2 Omaker M4 Battery Replacement: step 2, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Battery Replacement: step 3, image 1 of 2 Omaker M4 Battery Replacement: step 3, image 2 of 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Battery Replacement: step 4, image 1 of 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Battery Replacement: step 5, image 1 of 2 Omaker M4 Battery Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Battery Replacement, Battery: step 6, image 1 of 3 Omaker M4 Battery Replacement, Battery: step 6, image 2 of 3 Omaker M4 Battery Replacement, Battery: step 6, image 3 of 3
    • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
3 other people completed this guide.
Carlos Pernia
170 Reputation
1 Guide authored
USF Tampa, Team 2-2, Sullivan Spring 2016 Member of USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
3 Members
2 Guides authored
One Comment
What battery is required for this though? Is it easily found on amazon?
Mohsin - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,357
