OnHub Outer Casing Replacement
  1. OnHub Outer Casing Replacement, Speaker Grille: step 1, image 1 of 2 OnHub Outer Casing Replacement, Speaker Grille: step 1, image 2 of 2
    • Make sure the device is unplugged before proceeding with the disassembly.
    • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
  2. OnHub Outer Casing Replacement: step 2, image 1 of 1
    • Place the plastic opening tool under the speaker grille, and just above the light ring.
    • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
  3. OnHub Outer Casing Replacement: step 3, image 1 of 2 OnHub Outer Casing Replacement: step 3, image 2 of 2
    • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
    • There is a delicate wire connection to the antenna that is easily broken if not careful.
  4. OnHub Outer Casing Replacement, Congestion-sensing Antenna: step 4, image 1 of 2 OnHub Outer Casing Replacement, Congestion-sensing Antenna: step 4, image 2 of 2
    • Remove the wire connection to the antenna by soldering it off.
    • For help with soldering and de-soldering check out the iFixit Soldering Guide
  5. OnHub Outer Casing Replacement, Outer Casing: step 5, image 1 of 2 OnHub Outer Casing Replacement, Outer Casing: step 5, image 2 of 2
    • You must remove the plastic cover found just above the speaker.
    • Wedge the plastic opening tool under the cover and apply pressure in an upward direction.
    • There are four clips that you are removing. When disengaged, these clips will make a snapping noise.
    • Though the snapping noise is normal, take care not to break these clips.
  6. OnHub Outer Casing Replacement: step 6, image 1 of 1
    • Upon removing the cover, four screws and the speaker housing will be exposed.
    • Unscrew the four 12mm screws using a #1 Phillips head screwdriver.
    • This unlocks the speaker housing and antenna array from the casing.
  7. OnHub Outer Casing Replacement: step 7, image 1 of 2 OnHub Outer Casing Replacement: step 7, image 2 of 2
    • On the bottom of the OnHub is two screws holding the casing to the base.
    • To access these screws, you must remove the rubber pad that is glued to the base.
    • To remove the pad, slide a metal spudger under the edge of the pad. Pry the pad away from the base, removing the glue.
    • Once the pad is pulled up enough to grab, peel it the rest of the way exposing the screws.
    • The rubber pad is thin and fragile; be careful not to tear when removing.
  8. OnHub Outer Casing Replacement: step 8, image 1 of 1
    • Remove the two 12mm screws under the base of the OnHub by using a #1 Phillips head screwdriver.
  9. OnHub Outer Casing Replacement: step 9, image 1 of 2 OnHub Outer Casing Replacement: step 9, image 2 of 2
    • Once the two screws are removed from the base, it is time to split the casing apart.
    • It is okay if a couple clips break. It will still hold together with a few remaining.
    • Wedge a spudger between the two casing halves, and pry the clips apart starting from the top
    • There are three hooking style clips in total.
  10. OnHub Outer Casing Replacement: step 10, image 1 of 1
    • Once unclipped, you can slide the two casing halves apart, and remove the casing.
2 other people completed this guide.
Joseph Ainsworth
544 Reputation
3 Guides authored
USF Tampa, Team 3-3, Sullivan Spring 2016 Member of USF Tampa, Team 3-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G3
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 504
