Onda V701 Front- Facing Camera Replacement
  1. Onda V701 Front- Facing Camera Replacement, Back Panel: step 1, image 1 of 3 Onda V701 Front- Facing Camera Replacement, Back Panel: step 1, image 2 of 3 Onda V701 Front- Facing Camera Replacement, Back Panel: step 1, image 3 of 3
    • Ensure device is powered off before disassembly.
    • Remove the 4 rubber screw plugs using a spudger.
  2. Onda V701 Front- Facing Camera Replacement: step 2, image 1 of 3 Onda V701 Front- Facing Camera Replacement: step 2, image 2 of 3 Onda V701 Front- Facing Camera Replacement: step 2, image 3 of 3
    • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
  3. Onda V701 Front- Facing Camera Replacement: step 3, image 1 of 2 Onda V701 Front- Facing Camera Replacement: step 3, image 2 of 2
    • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
    • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
  4. Onda V701 Front- Facing Camera Replacement: step 4, image 1 of 2 Onda V701 Front- Facing Camera Replacement: step 4, image 2 of 2
    • Gently lift the screen assembly away from the back cover assembly.
    • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
  5. Onda V701 Front- Facing Camera Replacement: step 5, image 1 of 3 Onda V701 Front- Facing Camera Replacement: step 5, image 2 of 3 Onda V701 Front- Facing Camera Replacement: step 5, image 3 of 3
    • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
    • Remove the ribbon cables.
  6. Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: step 6, image 1 of 2 Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: step 6, image 2 of 2
    • Gently pry the front-facing camera away from the back panel using a spudger.
  7. Onda V701 Front- Facing Camera Replacement: step 7, image 1 of 2 Onda V701 Front- Facing Camera Replacement: step 7, image 2 of 2
    • Flip the gray locking tab of the ribbon connector up using a spudger.
    • Remove the ribbon cable from the connector.
  8. Onda V701 Front- Facing Camera Replacement: step 8, image 1 of 1
    • Remove the front-facing camera assembly.
Bradley Huber
366 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 368
