Onda V701 Screen Replacement
  1. Onda V701 Screen Replacement, Back Panel: step 1, image 1 of 3 Onda V701 Screen Replacement, Back Panel: step 1, image 2 of 3 Onda V701 Screen Replacement, Back Panel: step 1, image 3 of 3
    • Ensure device is powered off before disassembly.
    • Remove the 4 rubber screw plugs using a spudger.
  2. Onda V701 Screen Replacement: step 2, image 1 of 3 Onda V701 Screen Replacement: step 2, image 2 of 3 Onda V701 Screen Replacement: step 2, image 3 of 3
    • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
  3. Onda V701 Screen Replacement: step 3, image 1 of 2 Onda V701 Screen Replacement: step 3, image 2 of 2
    • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
    • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
  4. Onda V701 Screen Replacement: step 4, image 1 of 2 Onda V701 Screen Replacement: step 4, image 2 of 2
    • Gently lift the screen assembly away from the back cover assembly.
    • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
  5. Onda V701 Screen Replacement: step 5, image 1 of 3 Onda V701 Screen Replacement: step 5, image 2 of 3 Onda V701 Screen Replacement: step 5, image 3 of 3
    • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
    • Remove the ribbon cables.
  6. Onda V701 Screen Replacement, Screen: step 6, image 1 of 3 Onda V701 Screen Replacement, Screen: step 6, image 2 of 3 Onda V701 Screen Replacement, Screen: step 6, image 3 of 3
    • Remove all 14 of the 3.6mm screws using a PH00 screwdriver.
  7. Onda V701 Screen Replacement: step 7, image 1 of 3 Onda V701 Screen Replacement: step 7, image 2 of 3 Onda V701 Screen Replacement: step 7, image 3 of 3
    • Gently separate the screen from the plastic border/screen holder by pulling it off with your hands.
  8. Onda V701 Screen Replacement: step 8, image 1 of 3 Onda V701 Screen Replacement: step 8, image 2 of 3 Onda V701 Screen Replacement: step 8, image 3 of 3
    • Remove the grey monitor from the glass screen cover by gently lifting it up.
William Sioholm
104 Reputation
1 Guide authored
1 Guide Comment
بدي من هي الشاشة وين بلاقي
abdurrhman khrrat - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 571
