Onda VI10 Speaker Replacement
  1. Onda VI10 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Use a number 0 screw driver to remove the four screws.
  2. Onda VI10 Speaker Replacement: step 2, image 1 of 1
    • Power Button on the side should be pointing outward.
    • Note: This is so the ribbon cables inside are not damaged.
  3. Onda VI10 Speaker Replacement: step 3, image 1 of 1
    • Locate the black and red speaker wires going back to the mother board.
    • Note: Speaker wires may run underneath the battery wires.
  4. Onda VI10 Speaker Replacement: step 4, image 1 of 1
    • Carefully remove the speaker cables from the retaining tabs using a thin metal spudger.
  5. Onda VI10 Speaker Replacement: step 5, image 1 of 1
    • Pry the speaker out of its molding using a thin metal spudger
  6. Onda VI10 Speaker Replacement: step 6, image 1 of 1
    • Desolder the two speaker wires from the motherboard using a soldering iron.
    • Caution: Soldering Iron is extremely hot.
Carlos Diaz
101 Reputation
1 Guide authored
IUPUI, Team S4-G3, Baechle Spring 2017 Member of IUPUI, Team S4-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 157
