One Education Infinity Battery Replacement
  1. One Education Infinity Battery Replacement, Back Case: step 1, image 1 of 3 One Education Infinity Battery Replacement, Back Case: step 1, image 2 of 3 One Education Infinity Battery Replacement, Back Case: step 1, image 3 of 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Battery Replacement: step 2, image 1 of 2 One Education Infinity Battery Replacement: step 2, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Battery Replacement: step 3, image 1 of 3 One Education Infinity Battery Replacement: step 3, image 2 of 3 One Education Infinity Battery Replacement: step 3, image 3 of 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Battery Replacement, Battery: step 4, image 1 of 3 One Education Infinity Battery Replacement, Battery: step 4, image 2 of 3 One Education Infinity Battery Replacement, Battery: step 4, image 3 of 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Battery Replacement: step 5, image 1 of 3 One Education Infinity Battery Replacement: step 5, image 2 of 3 One Education Infinity Battery Replacement: step 5, image 3 of 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
Jacob Barnes
193 Reputation
2 Guides authored
Cal Poly, Team S11-G4, Regan Fall 2019 Member of Cal Poly, Team S11-G4, Regan Fall 2019
CPSU-REGAN-F19S11G4
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 18
All Time: 295
