One Education Infinity:One Dock Contact Assembly Replacement
  1. One Education Infinity:One Dock Contact Assembly Replacement, Battery: step 1, image 1 of 2 One Education Infinity:One Dock Contact Assembly Replacement, Battery: step 1, image 2 of 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Dock Contact Assembly Replacement: step 2, image 1 of 3 One Education Infinity:One Dock Contact Assembly Replacement: step 2, image 2 of 3 One Education Infinity:One Dock Contact Assembly Replacement: step 2, image 3 of 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Dock Contact Assembly Replacement: step 3, image 1 of 3 One Education Infinity:One Dock Contact Assembly Replacement: step 3, image 2 of 3 One Education Infinity:One Dock Contact Assembly Replacement: step 3, image 3 of 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Dock Contact Assembly Replacement: step 4, image 1 of 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Dock Contact Assembly Replacement, Dock Contact Assembly: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to pull the dock contact display cable away from the connector on the motherboard.
  6. One Education Infinity:One Dock Contact Assembly Replacement: step 6, image 1 of 1
    • Use a Phillips #000 screwdriver to unscrew the two 4.2mm screws from the circuit board containing the dock contact.
  7. One Education Infinity:One Dock Contact Assembly Replacement: step 7, image 1 of 1
    • Lift the dock contact assembly away from the device.
Taylor Bratsch
5,795 Reputation
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 165
