One Education Infinity:One Motherboard Replacement
  1. One Education Infinity:One Motherboard Replacement, Battery: step 1, image 1 of 2 One Education Infinity:One Motherboard Replacement, Battery: step 1, image 2 of 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Motherboard Replacement: step 2, image 1 of 3 One Education Infinity:One Motherboard Replacement: step 2, image 2 of 3 One Education Infinity:One Motherboard Replacement: step 2, image 3 of 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Motherboard Replacement: step 3, image 1 of 3 One Education Infinity:One Motherboard Replacement: step 3, image 2 of 3 One Education Infinity:One Motherboard Replacement: step 3, image 3 of 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Motherboard Replacement: step 4, image 1 of 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Motherboard Replacement, Antenna: step 5, image 1 of 2 One Education Infinity:One Motherboard Replacement, Antenna: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use ESD safe tweezers to disconnect the antenna from the motherboard.
  6. One Education Infinity:One Motherboard Replacement, Motherboard: step 6, image 1 of 3 One Education Infinity:One Motherboard Replacement, Motherboard: step 6, image 2 of 3 One Education Infinity:One Motherboard Replacement, Motherboard: step 6, image 3 of 3
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
  7. One Education Infinity:One Motherboard Replacement: step 7, image 1 of 1
    Buy
    • Use tweezers to pull the dock connection cable away from the motherboard.
  8. One Education Infinity:One Motherboard Replacement: step 8, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
    • Use a Phillips #000 screwdriver to unscrew the one 4.2mm screw.
  9. One Education Infinity:One Motherboard Replacement: step 9, image 1 of 1
    • Lift the protective shield away from the motherboard.
  10. One Education Infinity:One Motherboard Replacement: step 10, image 1 of 3 One Education Infinity:One Motherboard Replacement: step 10, image 2 of 3 One Education Infinity:One Motherboard Replacement: step 10, image 3 of 3
    • With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
    • Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
    • During reassembly, be sure to insert the cable into the connector up to the white line on the cable and then close the retaining flap.
  11. One Education Infinity:One Motherboard Replacement: step 11, image 1 of 1
    • Gently lift the motherboard away from the display assembly.
Taylor Bratsch
6,095 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 624
