One by Wacom Medium Disassembly
  1. One by Wacom Medium Disassembly, Preparing the device: step 1, image 1 of 2 One by Wacom Medium Disassembly, Preparing the device: step 1, image 2 of 2
    • Remove the pen from the pen holder
  2. One by Wacom Medium Disassembly, Remove screws: step 2, image 1 of 2 One by Wacom Medium Disassembly, Remove screws: step 2, image 2 of 2
    • Remove four rubber feet to reveal four Phillips #1 screws
    • Remove four Phillips #1 screws
  3. One by Wacom Medium Disassembly, Pry it open: step 3, image 1 of 2 One by Wacom Medium Disassembly, Pry it open: step 3, image 2 of 2
    • Use plastic pry tool to open the casing
    • To make this process easier, start prying from corners
    • Continue prying on every side till two casing sides are separated
  4. One by Wacom Medium Disassembly: step 4, image 1 of 3 One by Wacom Medium Disassembly: step 4, image 2 of 3 One by Wacom Medium Disassembly: step 4, image 3 of 3
    • Remove the mainboard from the casing
    • If the USB port has to be replaced, be sure to remove the shielding from the back of the mainboard to avoid damaging it by high temperature
3 other people completed this guide.
00004707
1,157 Reputation
5 Guides authored
1 Guide Comment
Thanks for helpin me, means alot, it got infested by ants idk why but this helped me alot, this drawing tablet is pretty expensive for me since im just a student. Thank you once again.
Onee Kun - Reply
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 86
All Time: 4,324
