OnePlus 2 Charging Port Replacement
  1. OnePlus 2 Charging Port Replacement, SIM Card: step 1, image 1 of 3 OnePlus 2 Charging Port Replacement, SIM Card: step 1, image 2 of 3 OnePlus 2 Charging Port Replacement, SIM Card: step 1, image 3 of 3
    • Make sure that your phone is turned off before proceeding
    • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
  2. OnePlus 2 Charging Port Replacement: step 2, image 1 of 3 OnePlus 2 Charging Port Replacement: step 2, image 2 of 3 OnePlus 2 Charging Port Replacement: step 2, image 3 of 3
    • Locate the SIM card tray on the back of the phone
    • Use your thumb to gently slide out the tray
  3. OnePlus 2 Charging Port Replacement: step 3, image 1 of 1
    • Remove the SIM card tray
  4. OnePlus 2 Charging Port Replacement, Battery: step 4, image 1 of 3 OnePlus 2 Charging Port Replacement, Battery: step 4, image 2 of 3 OnePlus 2 Charging Port Replacement, Battery: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Find and carefully remove all 6 rubber screw covers with the tweezers.
    • Unscrew all 18 screws from the mid frame.
  5. OnePlus 2 Charging Port Replacement: step 5, image 1 of 3 OnePlus 2 Charging Port Replacement: step 5, image 2 of 3 OnePlus 2 Charging Port Replacement: step 5, image 3 of 3
    • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
    • Slowly work your way around the phone releasing all the clips that hold the frame in place.
  6. OnePlus 2 Charging Port Replacement: step 6, image 1 of 3 OnePlus 2 Charging Port Replacement: step 6, image 2 of 3 OnePlus 2 Charging Port Replacement: step 6, image 3 of 3
    • Using the spudger tool, pry the battery up from the adhesive.
    • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
  7. OnePlus 2 Charging Port Replacement, Charging Port: step 7, image 1 of 2 OnePlus 2 Charging Port Replacement, Charging Port: step 7, image 2 of 2
    • Use the spudger tool to pry up the top connection of the charging port.
    • Follow the cable with the spudger and slowly pry it up from the adhesive holding it down.
    • Stop at the next connection.
  8. OnePlus 2 Charging Port Replacement: step 8, image 1 of 3 OnePlus 2 Charging Port Replacement: step 8, image 2 of 3 OnePlus 2 Charging Port Replacement: step 8, image 3 of 3
    • Again, using the spudger tool, pry up the final 4 connections on the charging port
    • Again, just like before, slowly follow the cable with the spudger tool lifting it up from the adhesive backing.
  9. OnePlus 2 Charging Port Replacement: step 9, image 1 of 3 OnePlus 2 Charging Port Replacement: step 9, image 2 of 3 OnePlus 2 Charging Port Replacement: step 9, image 3 of 3
    • Using the spudger tool on the bottom of the phone, push the charging part inward.
    • Once the charging port is free from the frame, use your fingers to remove the charging port the rest of the way.
21 other people completed this guide.
Kayla Williams
1,544 Reputation
6 Guides authored
Cal Poly, Team 4-5, Maness Fall 2015 Member of Cal Poly, Team 4-5, Maness Fall 2015
CPSU-MANESS-F15S4G5
4 Members
19 Guides authored
9 Guide Comments
How do you get the replacement USB type c port?
Ben King - Reply
I need it. If you can help
Mamdouh -
I need that part please. I need to buy it my phone stoped charging and need charging port with it's falt cable.. Please help me
My email is :mamdouh1978@gmail.com
Mamdouh - Reply
I need this part also. You can help me, please?
Enric Fransoy -
can you tell me why 2 pins on Charigng Port Flex ?? can I add wireless charger from it? please reply at atulmits@gmail.com
Atul Mandal - Reply
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 81
All Time: 16,263
