OnePlus 2 Motherboard Replacement
  1. OnePlus 2 Motherboard Replacement, SIM Card: step 1, image 1 of 3 OnePlus 2 Motherboard Replacement, SIM Card: step 1, image 2 of 3 OnePlus 2 Motherboard Replacement, SIM Card: step 1, image 3 of 3
    • Make sure that your phone is turned off before proceeding
    • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
  2. OnePlus 2 Motherboard Replacement: step 2, image 1 of 3 OnePlus 2 Motherboard Replacement: step 2, image 2 of 3 OnePlus 2 Motherboard Replacement: step 2, image 3 of 3
    • Locate the SIM card tray on the back of the phone
    • Use your thumb to gently slide out the tray
  3. OnePlus 2 Motherboard Replacement: step 3, image 1 of 1
    • Remove the SIM card tray
  4. OnePlus 2 Motherboard Replacement, Battery: step 4, image 1 of 3 OnePlus 2 Motherboard Replacement, Battery: step 4, image 2 of 3 OnePlus 2 Motherboard Replacement, Battery: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Find and carefully remove all 6 rubber screw covers with the tweezers.
    • Unscrew all 18 screws from the mid frame.
  5. OnePlus 2 Motherboard Replacement: step 5, image 1 of 3 OnePlus 2 Motherboard Replacement: step 5, image 2 of 3 OnePlus 2 Motherboard Replacement: step 5, image 3 of 3
    • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
    • Slowly work your way around the phone releasing all the clips that hold the frame in place.
  6. OnePlus 2 Motherboard Replacement: step 6, image 1 of 3 OnePlus 2 Motherboard Replacement: step 6, image 2 of 3 OnePlus 2 Motherboard Replacement: step 6, image 3 of 3
    • Using the spudger tool, pry the battery up from the adhesive.
    • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
  7. OnePlus 2 Motherboard Replacement, Front and Rear Camera: step 7, image 1 of 3 OnePlus 2 Motherboard Replacement, Front and Rear Camera: step 7, image 2 of 3 OnePlus 2 Motherboard Replacement, Front and Rear Camera: step 7, image 3 of 3
    • Use the spudger tool to pry off the connections at the bottom-right of the front-facing camera.
    • Be sure to disconnect both connections before attempting to lift off the wiring.
  8. OnePlus 2 Motherboard Replacement: step 8, image 1 of 2 OnePlus 2 Motherboard Replacement: step 8, image 2 of 2
    • Use the spudger tool to pry off the connection on the left of the front facing camera.
  9. OnePlus 2 Motherboard Replacement: step 9, image 1 of 2 OnePlus 2 Motherboard Replacement: step 9, image 2 of 2
    Buy
    • Use the tweezers to lift up the camera from its groove.
    • The camera has a long, flat portion at the bottom, so be sure to slide the camera up while lifting it up.
  10. OnePlus 2 Motherboard Replacement: step 10, image 1 of 3 OnePlus 2 Motherboard Replacement: step 10, image 2 of 3 OnePlus 2 Motherboard Replacement: step 10, image 3 of 3
    • Use a spudger to pry off the connection below the front-facing camera.
    • Using the tweezers, carefully remove the camera from its groove.
  11. OnePlus 2 Motherboard Replacement, Charging Port: step 11, image 1 of 2 OnePlus 2 Motherboard Replacement, Charging Port: step 11, image 2 of 2
    • Use the spudger tool to pry up the top connection of the charging port.
    • Follow the cable with the spudger and slowly pry it up from the adhesive holding it down.
    • Stop at the next connection.
  12. OnePlus 2 Motherboard Replacement: step 12, image 1 of 3 OnePlus 2 Motherboard Replacement: step 12, image 2 of 3 OnePlus 2 Motherboard Replacement: step 12, image 3 of 3
    • Again, using the spudger tool, pry up the final 4 connections on the charging port
    • Again, just like before, slowly follow the cable with the spudger tool lifting it up from the adhesive backing.
  13. OnePlus 2 Motherboard Replacement: step 13, image 1 of 3 OnePlus 2 Motherboard Replacement: step 13, image 2 of 3 OnePlus 2 Motherboard Replacement: step 13, image 3 of 3
    • Using the spudger tool on the bottom of the phone, push the charging part inward.
    • Once the charging port is free from the frame, use your fingers to remove the charging port the rest of the way.
  14. OnePlus 2 Motherboard Replacement, Motherboard: step 14, image 1 of 2 OnePlus 2 Motherboard Replacement, Motherboard: step 14, image 2 of 2
    • Use the spudger tool to pry off the long wire connecting the motherboard (top) and the daughter-board (bottom).
    • Try to use the spudger to pry off as much of the wire as possible before attempting to remove it.
  15. OnePlus 2 Motherboard Replacement: step 15, image 1 of 3 OnePlus 2 Motherboard Replacement: step 15, image 2 of 3 OnePlus 2 Motherboard Replacement: step 15, image 3 of 3
    • Use the spudger tool to pry off the 2 connections at the bottom-left of the motherboard.
  16. OnePlus 2 Motherboard Replacement: step 16, image 1 of 1
    • Use the screwdriver to unscrew the screw fastened at the bottom right of the motherboard.
  17. OnePlus 2 Motherboard Replacement: step 17, image 1 of 2 OnePlus 2 Motherboard Replacement: step 17, image 2 of 2
    • Use the spudger tool to pry up the connection at the top of the motherboard.
  18. OnePlus 2 Motherboard Replacement: step 18, image 1 of 3 OnePlus 2 Motherboard Replacement: step 18, image 2 of 3 OnePlus 2 Motherboard Replacement: step 18, image 3 of 3
    • Insert the spudger tool underneath the bottom right corner of the motherboard.
    • Gently work your way around the underside of the board, making sure that it is completely detached before attempting to remove it.
13 other people completed this guide.
Kayla Williams
1,541 Reputation
6 Guides authored
Cal Poly, Team 4-5, Maness Fall 2015 Member of Cal Poly, Team 4-5, Maness Fall 2015
CPSU-MANESS-F15S4G5
4 Members
19 Guides authored
3 Comments
Perfect. How can change de microphone and audio plug?
something?
Adolfo Mendoza Gutierrez - Reply
where can i find the replace of the motherboard?
Georgina Patron - Reply
hi,
where the wifi antena location?
Nimrod Cohen - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 12,562
