OnePlus 3 Battery Disconnect
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. OnePlus 3 Battery Disconnect, OnePlus 3 Battery Disconnect: step 1, image 1 of 2 OnePlus 3 Battery Disconnect, OnePlus 3 Battery Disconnect: step 1, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket, located above the top right corner of the battery pack.
    • Bend the connector away from the socket to prevent accidental contact.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
Arthur Shi
323,375 Reputation
793 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,225 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 30
All Time: 119
