OnePlus 3 USB Type-C Port Replacement
Video Instructions
25 other people completed this guide.
Witrigs
69,881 Reputation
378 Guides authored
14 Comments
I broke 5 spudgers getting the screen to separate from the back because dirt had built up around the edge this is also the reason the usb port died. consider buying extra spudgers when doing your repair.
RayZ fox - Reply
consider keeping your phone clean.
MO MOBILE - Reply
Is the same charging port used on the 3T?
thisisian - Reply
I successfully followed this guide, to replace the charging port on an UK 3T phone (it seems like the same part, I bought it on ebay).
The hardest part was getting the first spudger into the phone case, which took me at least 20 minutes (first time trying this). As noted make sure you have spares.
I had a little trouble reconnecting the lower round gold power connector as the cable had shifted a bit during taking out the component it connects to and it was very sensitive to position to go in right.
Having the high quality driver set from ifixit made a huge difference as I’d have spent ages fiddling if the driver was not magnetized for lifting the tiny screws in and out.
Steve -
Perfect ! +-20 min. just be sure to check the rubber of the charging port and aux cable are in the right position before placing the cover back
Yorgi D'Haese - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 32
All Time: 25,338
