OnePlus 5T Back Cover Replacement
  1. OnePlus 5T Back Cover Replacement, Back Cover: step 1, image 1 of 2 OnePlus 5T Back Cover Replacement, Back Cover: step 1, image 2 of 2
    • Before you begin, switch off your phone.
    • Remove the SIM card tray.
  2. OnePlus 5T Back Cover Replacement: step 2, image 1 of 1
    • Remove the two Torx T2 screws (2.5 mm length).
    • The OnePlus 5T doesn't use a lot of adhesive to secure the backcover, however the clamps are very strong and require some force during the opening procedure.
  3. OnePlus 5T Back Cover Replacement: step 3, image 1 of 3 OnePlus 5T Back Cover Replacement: step 3, image 2 of 3 OnePlus 5T Back Cover Replacement: step 3, image 3 of 3
    • Insert an opening tool between the display and the backcover at the bottom end of the phone.
    • Use the opening tool to create a gap between back cover and display.
    • Insert an opening pick in the gap you created with the opening tool.
  4. OnePlus 5T Back Cover Replacement: step 4, image 1 of 3 OnePlus 5T Back Cover Replacement: step 4, image 2 of 3 OnePlus 5T Back Cover Replacement: step 4, image 3 of 3
    • Slide the opening pick to the bottom right corner of the phone.
    • Insert a second opening pick and slide it to the bottom left corner of the phone.
  5. OnePlus 5T Back Cover Replacement: step 5, image 1 of 3 OnePlus 5T Back Cover Replacement: step 5, image 2 of 3 OnePlus 5T Back Cover Replacement: step 5, image 3 of 3
    • Slide the opening pick around the bottom left corner and then up along the left edge of the phone to open the plastic clamps that secure the backcover.
  6. OnePlus 5T Back Cover Replacement: step 6, image 1 of 3 OnePlus 5T Back Cover Replacement: step 6, image 2 of 3 OnePlus 5T Back Cover Replacement: step 6, image 3 of 3
    • Slide the opening pick around the bottom right corner and then up along the right edge of the phone to open the plastic clamps that secure the backcover.
  7. OnePlus 5T Back Cover Replacement: step 7, image 1 of 3 OnePlus 5T Back Cover Replacement: step 7, image 2 of 3 OnePlus 5T Back Cover Replacement: step 7, image 3 of 3
    • Try not to remove the backcover all the way yet. The fingerprint and the charging port and headphone flex cables are still connected to the motherboard.
    • Flip your phone and carefully lift the bottom end of the backcover away from the phone assembly. Fold it to left and hold it at an 80° angle.
  8. OnePlus 5T Back Cover Replacement: step 8, image 1 of 2 OnePlus 5T Back Cover Replacement: step 8, image 2 of 2
    • Use a spudger to pry up and disconnect the fingerprint flex cable.
  9. OnePlus 5T Back Cover Replacement: step 9, image 1 of 3 OnePlus 5T Back Cover Replacement: step 9, image 2 of 3 OnePlus 5T Back Cover Replacement: step 9, image 3 of 3
    • Twist the backcover around 180° and lay it down to align the bottom end of the backcover the top edge of the battery.
  10. OnePlus 5T Back Cover Replacement: step 10, image 1 of 3 OnePlus 5T Back Cover Replacement: step 10, image 2 of 3 OnePlus 5T Back Cover Replacement: step 10, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the small metal shield which covers the battery and the charging port and headphone jack flex cable connectors.
  11. OnePlus 5T Back Cover Replacement: step 11, image 1 of 2 OnePlus 5T Back Cover Replacement: step 11, image 2 of 2
    • Use a spudger to pry up and disconnect the charging port and headphone jack flex cable.
  12. OnePlus 5T Back Cover Replacement: step 12, image 1 of 2 OnePlus 5T Back Cover Replacement: step 12, image 2 of 2
    • Remove the backcover.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
6 other people completed this guide.
Dominik Schnabelrauch
247,918 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,788 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 34
All Time: 3,953
