OnePlus 6 Lower Frame Replacement
  1. OnePlus 6 Lower Frame Replacement, Back Panel: step 1, image 1 of 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Lower Frame Replacement: step 2, image 1 of 2 OnePlus 6 Lower Frame Replacement: step 2, image 2 of 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Lower Frame Replacement: step 3, image 1 of 2 OnePlus 6 Lower Frame Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Lower Frame Replacement, Lower Frame: step 4, image 1 of 2 OnePlus 6 Lower Frame Replacement, Lower Frame: step 4, image 2 of 2
    • Using the Phillips #00 screwdriver, remove the eight 3 mm screws from the lower frame.
    • Gently lift the lower panel up and out of the device.
Mickenzie Thompson
358 Reputation
3 Guides authored
Clemson, Team 4-3, Hunter Fall 2021 Member of Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 786
