OnePlus 6 Speaker Replacement
  1. OnePlus 6 Speaker Replacement, Back Panel: step 1, image 1 of 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Speaker Replacement: step 2, image 1 of 2 OnePlus 6 Speaker Replacement: step 2, image 2 of 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Speaker Replacement: step 3, image 1 of 2 OnePlus 6 Speaker Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Speaker Replacement, Battery: step 4, image 1 of 2 OnePlus 6 Speaker Replacement, Battery: step 4, image 2 of 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
  5. OnePlus 6 Speaker Replacement, Speaker: step 5, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the eight screws.
    • Carefully lift the speaker up and out of the chassis.
    • If you're completing a screen replacement, skip to Step 9.
  6. OnePlus 6 Speaker Replacement: step 6, image 1 of 1
    • Properly orient the new speaker unit and use a Phillips #000 screwdriver to replace the eight screws removed from the previous step.
  7. OnePlus 6 Speaker Replacement: step 7, image 1 of 1
    • Place the battery back into the phone and connect it to the same port, making sure to firmly press the connection down into place.
    • Place the red cover back over the top of the port.
  8. OnePlus 6 Speaker Replacement: step 8, image 1 of 1
    • Strip the existing adhesive, and place new adhesive around the entire perimeter of the back cover.
    • Replace the back cover and hold it down for about a minute to to let the adhesive set.
Enjoy your new speaker!
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,016
