OnePlus 6T Front Camera Replacement
  1. OnePlus 6T Front Camera Replacement, Back Cover: step 1, image 1 of 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Front Camera Replacement: step 2, image 1 of 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
  3. OnePlus 6T Front Camera Replacement: step 3, image 1 of 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Front Camera Replacement: step 4, image 1 of 3 OnePlus 6T Front Camera Replacement: step 4, image 2 of 3 OnePlus 6T Front Camera Replacement: step 4, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
  5. OnePlus 6T Front Camera Replacement, Front Camera: step 5, image 1 of 2 OnePlus 6T Front Camera Replacement, Front Camera: step 5, image 2 of 2
    Buy
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
  6. OnePlus 6T Front Camera Replacement: step 6, image 1 of 1
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
  7. OnePlus 6T Front Camera Replacement: step 7, image 1 of 1
    • Using a spudger, gently remove the midframe and place it to the side.
  8. OnePlus 6T Front Camera Replacement: step 8, image 1 of 1
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
2 other people completed this guide.
Kristen Gismondi
102,211 Reputation
266 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,920 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 1,500
