OnePlus 7 Pro Screen Replacement
Video Overview
  1. OnePlus 7 Pro Screen Replacement, OnePlus 7 Pro Screen Replacement: step 1, image 1 of 3 OnePlus 7 Pro Screen Replacement, OnePlus 7 Pro Screen Replacement: step 1, image 2 of 3 OnePlus 7 Pro Screen Replacement, OnePlus 7 Pro Screen Replacement: step 1, image 3 of 3
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. OnePlus 7 Pro Screen Replacement: step 2, image 1 of 2 OnePlus 7 Pro Screen Replacement: step 2, image 2 of 2
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
  3. OnePlus 7 Pro Screen Replacement: step 3, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 3, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 3, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
  4. OnePlus 7 Pro Screen Replacement: step 4, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 4, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 4, image 3 of 3
    • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
  5. OnePlus 7 Pro Screen Replacement: step 5, image 1 of 2 OnePlus 7 Pro Screen Replacement: step 5, image 2 of 2
    • Remove the phone's back cover.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
  6. OnePlus 7 Pro Screen Replacement: step 6, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 6, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 6, image 3 of 3
    Buy
    • Use a pair of tweezers to lift up the piece of black tape covering the laser autofocus and flash flex cable.
    • Use a pair of tweezers to lift and remove the covering on the laser autofocus and flash flex cable.
  7. OnePlus 7 Pro Screen Replacement: step 7, image 1 of 1
    • Use the flat end of a spudger to disconnect the laser autofocus and flash flex cable.
  8. OnePlus 7 Pro Screen Replacement: step 8, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the fourteen screws from the plastic motherboard cover.
  9. OnePlus 7 Pro Screen Replacement: step 9, image 1 of 2 OnePlus 7 Pro Screen Replacement: step 9, image 2 of 2
    • Use the flat end of a spudger to lift up the plastic motherboard cover.
    • Remove the plastic motherboard cover.
  10. OnePlus 7 Pro Screen Replacement: step 10, image 1 of 1
    • Use the flat end of a spudger to disconnect the power flex cable.
  11. OnePlus 7 Pro Screen Replacement: step 11, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 11, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 11, image 3 of 3
    • Use the flat end of a spudger to disconnect the longer black coaxial cable.
    • Use the flat end of a spudger to disconnect the white coaxial cable.
    • Use the flat end of a spudger to disconnect the shorter black coaxial cable.
  12. OnePlus 7 Pro Screen Replacement: step 12, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 12, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 12, image 3 of 3
    • Use the flat end of a spudger to disconnect the display and touch flex cable, main flex cable, and USB port cable.
  13. OnePlus 7 Pro Screen Replacement: step 13, image 1 of 1
    • Use the flat end of a spudger to disconnect the black cable on the left-hand side of the phone.
  14. OnePlus 7 Pro Screen Replacement: step 14, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 14, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 14, image 3 of 3
    • Use the flat end of a spudger to pry up the long black cable on the left-hand side of the phone.
    • Use the flat end of a spudger to disconnect the end of the long black cable.
  15. OnePlus 7 Pro Screen Replacement: step 15, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 15, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 15, image 3 of 3
    • Use a pair of tweezers to pry up the red plastic tab.
    • Use a pair of tweezers to remove the assembly connected to the red plastic tab.
  16. OnePlus 7 Pro Screen Replacement: step 16, image 1 of 1
    • Use the flat end of a spudger to disconnect the connector that was underneath the red plastic tab.
  17. OnePlus 7 Pro Screen Replacement: step 17, image 1 of 2 OnePlus 7 Pro Screen Replacement: step 17, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the remaining two screws securing the motherboard.
  18. OnePlus 7 Pro Screen Replacement: step 18, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 18, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 18, image 3 of 3
    • Use the flat end of a spudger to lift up the phone's motherboard.
    • Remove the motherboard.
  19. OnePlus 7 Pro Screen Replacement: step 19, image 1 of 2 OnePlus 7 Pro Screen Replacement: step 19, image 2 of 2
    • Use a Phillips #000 screwdriver to remove two short screws.
    • Use a Phillips #000 screwdriver to remove one screw.
  20. OnePlus 7 Pro Screen Replacement: step 20, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 20, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 20, image 3 of 3
    • Use a pair of tweezers to remove the camera elevator assembly.
  21. OnePlus 7 Pro Screen Replacement: step 21, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 21, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 21, image 3 of 3
    • Lift up the large flex cable with your fingers.
    • Use a pair of tweezers to remove the black plastic screw covering.
  22. OnePlus 7 Pro Screen Replacement: step 22, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 22, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 22, image 3 of 3
    • Use a Phillips #000 screwdriver to remove two small screws from the metal covering.
    • Remove the metal covering.
  23. OnePlus 7 Pro Screen Replacement: step 23, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 23, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 23, image 3 of 3
    • Use the flat end of a spudger or your fingers to gently remove the front camera assembly.
  24. OnePlus 7 Pro Screen Replacement: step 24, image 1 of 2 OnePlus 7 Pro Screen Replacement: step 24, image 2 of 2
    • Use a Phillips #000 screwdriver to remove one screw in the upper left-hand corner.
  25. OnePlus 7 Pro Screen Replacement: step 25, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 25, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 25, image 3 of 3
    • Use a pair of tweezers to disconnect the earpiece's yellow flex cable.
    • Use a pair of tweezers to remove the earpice.
  26. OnePlus 7 Pro Screen Replacement: step 26, image 1 of 2 OnePlus 7 Pro Screen Replacement: step 26, image 2 of 2
    • Use your fingers to pull on the red sticker labelled 'Pull Up From This Side.'
    • Remove the battery.
  27. OnePlus 7 Pro Screen Replacement: step 27, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 27, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 27, image 3 of 3
    • Use your fingers to grab the black tab and remove the plastic that was underneath the battery.
  28. OnePlus 7 Pro Screen Replacement: step 28, image 1 of 2 OnePlus 7 Pro Screen Replacement: step 28, image 2 of 2
    • Use a Phillips #000 screwdriver to remove eight screws from the bottom panel.
    • Use the flat end of a spudger to pry up the bottom cover.
    • Remove the bottom cover.
  29. OnePlus 7 Pro Screen Replacement: step 29, image 1 of 1
    • Use the flat end of a spudger to disconnect the fingerprint sensor, the LED flex cable, the CED flex cable, and the display and touch flex cable.
  30. OnePlus 7 Pro Screen Replacement: step 30, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 30, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 30, image 3 of 3
    • Use the flat end of a spudger to disconnect the three coaxial cables near the bottom of the phone.
    • To disconnect the longer coaxial cable, you will need to pry the wire from its clips.
  31. OnePlus 7 Pro Screen Replacement: step 31, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 31, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 31, image 3 of 3
    • Use the flat end of a spudger to lift up the sub-board.
    • Remove the phone's sub-board.
  32. OnePlus 7 Pro Screen Replacement: step 32, image 1 of 2 OnePlus 7 Pro Screen Replacement: step 32, image 2 of 2
    • Use a Phillips #000 screwdriver to remove two screws.
  33. OnePlus 7 Pro Screen Replacement: step 33, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 33, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 33, image 3 of 3
    • Use a pair of tweezers to peel out the black stickers from the sides and bottom of the battery area.
  34. OnePlus 7 Pro Screen Replacement: step 34, image 1 of 2 OnePlus 7 Pro Screen Replacement: step 34, image 2 of 2
    • Use your fingers to remove the three signal cables.
  35. OnePlus 7 Pro Screen Replacement: step 35, image 1 of 1
    • Use the flat end of a spudger to disconnect the USB port flex cable.
  36. OnePlus 7 Pro Screen Replacement: step 36, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 36, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 36, image 3 of 3
    • Use your fingers to remove the LED flex cable, CED flex cable, and USB port cable.
  37. OnePlus 7 Pro Screen Replacement: step 37, image 1 of 2 OnePlus 7 Pro Screen Replacement: step 37, image 2 of 2
    • Use a pair of tweezers to disconnect the fingerprint sensor.
  38. OnePlus 7 Pro Screen Replacement: step 38, image 1 of 1
    • Remove the vibration sensor using a pair of tweezers.
  39. OnePlus 7 Pro Screen Replacement: step 39, image 1 of 1
    • Disconnect the coaxial cable in the lower left-hand corner using the flat end of a spudger.
  40. OnePlus 7 Pro Screen Replacement: step 40, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 40, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 40, image 3 of 3
    • Use a Phillips #000 screwdriver to remove two screws on the left-hand side of the phone's frame.
    • Use a pair of tweezers to remove the plastic piece that was secured with the two previous screws.
  41. OnePlus 7 Pro Screen Replacement: step 41, image 1 of 3 OnePlus 7 Pro Screen Replacement: step 41, image 2 of 3 OnePlus 7 Pro Screen Replacement: step 41, image 3 of 3
    • Remove the coaxial cable using the flat end of a spudger.
    • Remove the coaxial cable from the left-hand side of the battery's area.
To reassemble your device, install each of the components removed during this guide into a new screen with a frame by following these instructions in reverse order.
9 other people completed this guide.
Selena
2,866 Reputation
14 Guides authored
12 Guide Comments
So I have a friend that owns this phone and has had the screen replaced, there is however some misalignment of the screen and frame on her phone in the form of a very obvious crack between the two, the two surfaces are also not flush. Could someone in theory have improperly repaired the phone by separating the screen from the frame and gluing a new one in place?
Thank you and have a nice day.
Clayton Lawliss - Reply
No that is due to the frame being bent, if it is bent the screen will not sit properly and it is a difficult task to un bend a frame but it is possible.
Zach Benson -
Is it possible to replace just the top glass if the rest of the screen is intact? It's got surface cracks both front and back.
MJ Mulenga III - Reply
No don't and I mean DONT go that route the glass or whatever seems cheaper but the repair of separating them is next to impossible. Its like trying to take a part two potatoe chips that have been glued together and in the process not breaking either. Get a screen replacement.
Zach Benson -
Absolutely none of this is necessary as they don’t sell the screen with the frame. If you’re unlucky like me you’ll get the entire phone apart and then it will tell you to reassemble parts onto screen WITH frame.
Joel Tool - Reply
Past 24 Hours: 19
Past 7 Days: 164
Past 30 Days: 556
All Time: 23,168
