OnePlus 8 Rear Glass Replacement
  1. OnePlus 8 Rear Glass Replacement, Heat the rear glass: step 1, image 1 of 1
    • Power off your phone and unplug any cables.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
  2. OnePlus 8 Rear Glass Replacement, Insert an opening pick: step 2, image 1 of 3 OnePlus 8 Rear Glass Replacement, Insert an opening pick: step 2, image 2 of 3 OnePlus 8 Rear Glass Replacement, Insert an opening pick: step 2, image 3 of 3
    • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
    • Insert an opening pick into the gap.
  3. OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: step 3, image 1 of 3 OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: step 3, image 2 of 3 OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: step 3, image 3 of 3
    • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
  4. OnePlus 8 Rear Glass Replacement: step 4, image 1 of 3 OnePlus 8 Rear Glass Replacement: step 4, image 2 of 3 OnePlus 8 Rear Glass Replacement: step 4, image 3 of 3
    • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  5. OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: step 5, image 1 of 3 OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: step 5, image 2 of 3 OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: step 5, image 3 of 3
    • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
    • Insert a third opening pick under the bottom left corner of the rear glass.
    • Slide the opening pick up the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: step 6, image 1 of 3 OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: step 6, image 2 of 3 OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: step 6, image 3 of 3
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: step 7, image 1 of 3 OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: step 7, image 2 of 3 OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: step 7, image 3 of 3
    • Insert a fifth opening pick under the top right corner of the rear glass.
    • Slide the opening pick down the right edge to slice the remaining adhesive.
  8. OnePlus 8 Rear Glass Replacement, Remove the rear glass: step 8, image 1 of 3 OnePlus 8 Rear Glass Replacement, Remove the rear glass: step 8, image 2 of 3 OnePlus 8 Rear Glass Replacement, Remove the rear glass: step 8, image 3 of 3
    • Remove the rear glass.
    • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly:
    • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Manuel Haeussermann
23,380 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
123 Members
24,048 Guides authored
1 Guide Comment
hi, vielen Dank für die detaillierte Anleitung! Das hilft mega! Habt ihr evtl. noch eine Quelle, wo man das Backglass beziehen kann?
Thilo Cestonaro - Reply
Past 24 Hours: 6
Past 7 Days: 15
Past 30 Days: 81
All Time: 3,442
