OnePlus Nord N200 Sub Board Replacement
  1. OnePlus Nord N200 Sub Board Replacement, Sub/Charger Board: step 1, image 1 of 3 OnePlus Nord N200 Sub Board Replacement, Sub/Charger Board: step 1, image 2 of 3 OnePlus Nord N200 Sub Board Replacement, Sub/Charger Board: step 1, image 3 of 3
    • Take sim tray out prior to beginning repair.
    • Heat back of phone to make the adhesion more pliable
    • Insert a slim prying tool to begin removing the back cover, move in a counterclockwise direction
    • Add IPA as you work to detatch the adhesion layer
    • When approaching the volume button, be cautious, as the ribbon cable is exposed and can easilyt be cut
    • Remove back cover
  2. OnePlus Nord N200 Sub Board Replacement: step 2, image 1 of 3 OnePlus Nord N200 Sub Board Replacement: step 2, image 2 of 3 OnePlus Nord N200 Sub Board Replacement: step 2, image 3 of 3
    • Using a J000 screwdriver, remove the Screws holding the edge casing to the screen (19 Total)
    • Using a pry tool, seperate the edge plastic from the screen
    • Once you have attained suitable lift, disconnect the power button cable.
    • Remove the edge plastic and set aside.
  3. OnePlus Nord N200 Sub Board Replacement: step 3, image 1 of 1
    • Remove the plastic speaker piece
    • Disconnect the antenna cables and main board connector
    • Remove the board and insert new component
    • reconnect connectors
  4. OnePlus Nord N200 Sub Board Replacement: step 4, image 1 of 3 OnePlus Nord N200 Sub Board Replacement: step 4, image 2 of 3 OnePlus Nord N200 Sub Board Replacement: step 4, image 3 of 3
    • Reconnect the antenna and main board
    • Reconnect the power cable, and reattach the plastic edge
    • Using J000, screw the 19 screws back in
  5. OnePlus Nord N200 Sub Board Replacement: step 5, image 1 of 2 OnePlus Nord N200 Sub Board Replacement: step 5, image 2 of 2
    • Reconnect the back plastic, and set on heat to adhere
    • You can also use tesa tape to increase the adhesion.
This order can be used for charger, headphone jack, or water damage to sub board.
Jesse Smith
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 53
All Time: 552
