Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement
  1. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: step 1, image 1 of 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: step 1, image 2 of 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: step 2, image 1 of 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: step 2, image 2 of 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: step 2, image 3 of 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: step 3, image 1 of 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: step 3, image 2 of 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: step 3, image 3 of 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: step 4, image 1 of 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: step 4, image 2 of 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: step 4, image 3 of 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Auxiliary Port: step 5, image 1 of 1
    Buy
    • With your solderwick and soldering iron, remove the solder at each point, and gently pull the 3.5mm port away from the motherboard with your tweezers.
    • For more information on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 202
