Oontz Angle 3 ULTRA Micro USB Port Replacement
  1. Oontz Angle 3 ULTRA Micro USB Port Replacement, Back Panel: step 1, image 1 of 3 Oontz Angle 3 ULTRA Micro USB Port Replacement, Back Panel: step 1, image 2 of 3 Oontz Angle 3 ULTRA Micro USB Port Replacement, Back Panel: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA Micro USB Port Replacement: step 2, image 1 of 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: step 2, image 2 of 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: step 2, image 3 of 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA Micro USB Port Replacement: step 3, image 1 of 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: step 3, image 2 of 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: step 3, image 3 of 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA Micro USB Port Replacement: step 4, image 1 of 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: step 4, image 2 of 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: step 4, image 3 of 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA Micro USB Port Replacement, Micro USB Port: step 5, image 1 of 1
    • Gently push the ports away from the speaker enclosure with the spudger to free the motherboard.
  6. Oontz Angle 3 ULTRA Micro USB Port Replacement: step 6, image 1 of 1
    Buy
One Comment
These instructions are great, but they're useless unless you can find a replacement micro USB port… Any suggestions? Because I couldn't find one online that indicated it was compatible with the OontZ…
mango - Reply
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 63
All Time: 2,772
