Opening a bObi Robotic Vacuum
  1. Opening a bObi Robotic Vacuum, Top Cover: step 1, image 1 of 2 Opening a bObi Robotic Vacuum, Top Cover: step 1, image 2 of 2
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. Opening a bObi Robotic Vacuum: step 2, image 1 of 3 Opening a bObi Robotic Vacuum: step 2, image 2 of 3 Opening a bObi Robotic Vacuum: step 2, image 3 of 3
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. Opening a bObi Robotic Vacuum: step 3, image 1 of 3 Opening a bObi Robotic Vacuum: step 3, image 2 of 3 Opening a bObi Robotic Vacuum: step 3, image 3 of 3
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. Opening a bObi Robotic Vacuum: step 4, image 1 of 3 Opening a bObi Robotic Vacuum: step 4, image 2 of 3 Opening a bObi Robotic Vacuum: step 4, image 3 of 3
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
To reassemble bObi, refer to the closing guide. Closing bObi's Cover Post-Repair
Chelsea
2,278 Reputation
31 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 315
