Opening the Case
  1. Opening the Case, Opening the Case: step 1, image 1 of 1
    • Tool on left - PH000 screwdriver
    • Tool on right - iPod fix-it tool
    • Soldering Iron
  2. Opening the Case: step 2, image 1 of 1
    • Locate the 3 black screws on the bottom of the camera and the 2 gray screws on each side of the camera. Remove them with a PH000 screwdriver.
  3. Opening the Case: step 3, image 1 of 2 Opening the Case: step 3, image 2 of 2
    • Locate the gray band that you removed the screws from; this holds the two halves of the camera together. Use an iPod fix-it tool to pry the gray band loose and remove it.
  4. Opening the Case: step 4, image 1 of 1
    • Use the iPod fix-it tool to separate the back panel from the camera.
Travis Buck
107 Reputation
2 Guides authored
Ohio State, Team 1-2, Buehl Fall 2012 Member of Ohio State, Team 1-2, Buehl Fall 2012
OSU-BUEHL-F12S1G2
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 816
