Introduction
This will show how to disassemble the case for the Jura Z7. This step will be necessary for most repairs.
Remove all attachments: water tank, drip tray, aroma lid
Behind the Jura sign are two screws with an oval head. They have to be removed.
These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit for their removal. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!!
This step shows how to remove the top cover
Remove the powder tray and all coffee beans.
The cover is fastened with three Torx T15 screws. Those are easily visible under the covers as well as the small cover on the left back side.
Remove the two Phillips screws on the bean container and remove the bean container.
Lift the cover upwards.
Repeat the steps in reverse order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
12 Comments
Hi,
Do you also have a detailed description how to disassemble the front part?
Because I need to replace the “Outlet gate black V2”, the black plastic part behind the logo at the front panel which has the tube for tea attached to it. This black plastic cover of the tube is broken and therefore I want to replace this part.
Thank you very much for your answer!
Sorry, No. I never did this fix. Perhaps one of those videos helps: https://www.youtube-nocookie.com/embed/0... and https://www.youtube-nocookie.com/embed/P...
Great photo's and directions, couldn't be clearer or more straightforward. Thank you so much!
I had a small hole in one of the internal clear water hoses right where the clip held it in place. I cut off just slightly more than a quarter inch of the hose to get safety past where the hole in the hose was; but then had to struggle to stretch the remaining hose, just that quarter of an inch that I cut off, to remount and get the clip back on. Finally got it back in place. To say Jura is stingy with their hose lengths is putting it mildly.
I have looked everyplace for that rather specialized hose to have some on hand for my next leak. The hose seems to be medical grade. Websites that sell it have ridiculous prices for just a few inches of the stuff. I would pay it if I could get a few feet, but inches for $20 or $30 dollars is insane. Do you know of a source where it can be purchased in longer lengths? Thanks again!
Thank you.
When I opened the machine all the hoses look to be the same size and type on my Jura Z9 (clear silicone hose with crisscrossed silver lines embedded in the silicone - presumably for reinforcement), however, researching hose size online for Z9 brings up different diameter hoses for each connection. Is this right, as they all looked to be the same diameter to me (I did not think to measure at the time I had the sides off). Thanks again!
