Optical Drive Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Optical Drive Removal, Uncover the back panel screws: step 1, image 1 of 2 Optical Drive Removal, Uncover the back panel screws: step 1, image 2 of 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Optical Drive Removal: step 2, image 1 of 3 Optical Drive Removal: step 2, image 2 of 3 Optical Drive Removal: step 2, image 3 of 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Optical Drive Removal, Remove the back panel screws: step 3, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Optical Drive Removal, Unclip the back panel: step 4, image 1 of 3 Optical Drive Removal, Unclip the back panel: step 4, image 2 of 3 Optical Drive Removal, Unclip the back panel: step 4, image 3 of 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Optical Drive Removal: step 5, image 1 of 2 Optical Drive Removal: step 5, image 2 of 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Optical Drive Removal, Remove the back panel: step 6, image 1 of 3 Optical Drive Removal, Remove the back panel: step 6, image 2 of 3 Optical Drive Removal, Remove the back panel: step 6, image 3 of 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Optical Drive Removal: step 7, image 1 of 3 Optical Drive Removal: step 7, image 2 of 3 Optical Drive Removal: step 7, image 3 of 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Optical Drive Removal, Unlatch the base: step 8, image 1 of 3 Optical Drive Removal, Unlatch the base: step 8, image 2 of 3 Optical Drive Removal, Unlatch the base: step 8, image 3 of 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  9. Optical Drive Removal, Twist and remove the base: step 9, image 1 of 3 Optical Drive Removal, Twist and remove the base: step 9, image 2 of 3 Optical Drive Removal, Twist and remove the base: step 9, image 3 of 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  10. Optical Drive Removal, Remove the optical drive screws: step 10, image 1 of 2 Optical Drive Removal, Remove the optical drive screws: step 10, image 2 of 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  11. Optical Drive Removal, Remove the vibration isolator: step 11, image 1 of 3 Optical Drive Removal, Remove the vibration isolator: step 11, image 2 of 3 Optical Drive Removal, Remove the vibration isolator: step 11, image 3 of 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  12. Optical Drive Removal, Disconnect the power and data cables: step 12, image 1 of 3 Optical Drive Removal, Disconnect the power and data cables: step 12, image 2 of 3 Optical Drive Removal, Disconnect the power and data cables: step 12, image 3 of 3
    Buy
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Always pull cables by their connectors and not the wires themselves.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  13. Optical Drive Removal, Remove the optical drive: step 13, image 1 of 2 Optical Drive Removal, Remove the optical drive: step 13, image 2 of 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
Finish Line
Carsten Frauenheim
159,409 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,235 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 194
