Optoma HD20 Focal Lens Replacement
  1. Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: step 1, image 1 of 2 Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: step 1, image 2 of 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Optoma HD20 Focal Lens Replacement: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Focal Lens Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Focal Lens Replacement: step 4, image 1 of 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Optoma HD20 Focal Lens Replacement, Focal Lens: step 5, image 1 of 1
    • Use a Phillips #1 screwdriver to unscrew the small black 2 mm screw on the side of the focal lens.
  6. Optoma HD20 Focal Lens Replacement: step 6, image 1 of 1
    • Remove the focal lens by twisting it clockwise until it comes off.
Trever
1,282 Reputation
6 Guides authored
Cal Poly, Team 21-23, Maness Winter 2015 Member of Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 41
All Time: 4,627
