Optoma HD20 Light Bulb Replacement
  1. Optoma HD20 Light Bulb Replacement, Rear Panel: step 1, image 1 of 2 Optoma HD20 Light Bulb Replacement, Rear Panel: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to loosen the screws that secure the panel on the bottom of the Optoma HD20.
  2. Optoma HD20 Light Bulb Replacement: step 2, image 1 of 1
    • Lift the panel off of the device.
  3. Optoma HD20 Light Bulb Replacement, Light Bulb Casing: step 3, image 1 of 1
    • Use a Phillips #1 screwdriver to loosen the two screws securing the black casing.
    • The screws don't come out all the way.
  4. Optoma HD20 Light Bulb Replacement: step 4, image 1 of 3 Optoma HD20 Light Bulb Replacement: step 4, image 2 of 3 Optoma HD20 Light Bulb Replacement: step 4, image 3 of 3
    • Remove the light bulb casing from the device.
    • Steps 5-9 are unnecessary if the replacement light bulb comes with housing.
  5. Optoma HD20 Light Bulb Replacement, Light Bulb: step 5, image 1 of 1
    • Remove the three 4.5 mm screws on the light bulb case.
  6. Optoma HD20 Light Bulb Replacement: step 6, image 1 of 1
    • Carefully remove the light bulb insulator from the light bulb casing.
  7. Optoma HD20 Light Bulb Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Gently pull the wires off of the pins using tweezers.
  8. Optoma HD20 Light Bulb Replacement: step 8, image 1 of 1
    • Remove the 4 screws on the back of the light bulb casing using a Phillips #1 screwdriver.
  9. Optoma HD20 Light Bulb Replacement: step 9, image 1 of 2 Optoma HD20 Light Bulb Replacement: step 9, image 2 of 2
    • Remove the casing, then gently pull out the old light bulb and replace it with the new one.
7 other people completed this guide.
Trever
1,264 Reputation
6 Guides authored
Cal Poly, Team 21-23, Maness Winter 2015 Member of Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Members
6 Guides authored
5 Comments
I recently replaced my bulb for the third time and the insulator had grown brittle I am guessing from the heat and it broke. I can't seem to find this part for sale anywhere. Does anyone know if is possible to purchase it?
Thomas - Reply
The screws in step 8 are extremely hard to get off. I went and bought proper screwdrivers before even attempting since theyre small, but in a day I've only managed to get one off and I'm having to resort to other tactics, even using a drill to just grind the heads off.
dv01_ - Reply
king@okinlamps.com
Need LAD60 20PCS
kingshen92 - Reply
The manual says the new light won’t come back on until a lamp reset I’d done via menu , but how can you see the text if the light isn’t on?????
Taringajohn - Reply
my hd 20 projects dull images i recently replaced my bulb for the first time successfully and i followed as per menu trying to bulb reset but it is not working and still image is dull how to solve the problem
kumar - Reply
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 33
All Time: 11,942
