Optoma HD72 Color Wheel Replacement
  1. Optoma HD72 Color Wheel Replacement, Upper Case: step 1, image 1 of 2 Optoma HD72 Color Wheel Replacement, Upper Case: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
  2. Optoma HD72 Color Wheel Replacement: step 2, image 1 of 1
    • Flip the device over and slightly lift the upper case, with care not to strain the two cables.
    • Disconnect the two cables that connect the top case to the motherboard.
    • Lift the upper case up and off.
  3. Optoma HD72 Color Wheel Replacement, Motherboard: step 3, image 1 of 3 Optoma HD72 Color Wheel Replacement, Motherboard: step 3, image 2 of 3 Optoma HD72 Color Wheel Replacement, Motherboard: step 3, image 3 of 3
    • Disconnect all of the cables that are connected to the motherboard.
  4. Optoma HD72 Color Wheel Replacement: step 4, image 1 of 1
    • Remove the four 2 mm Phillips screws that secure the motherboard.
    • Lift the motherboard up and out of the chassis.
  5. Optoma HD72 Color Wheel Replacement, Color Wheel: step 5, image 1 of 3 Optoma HD72 Color Wheel Replacement, Color Wheel: step 5, image 2 of 3 Optoma HD72 Color Wheel Replacement, Color Wheel: step 5, image 3 of 3
    • Remove the three 2 mm Phillips screws that secure the black housing.
    • Lift the black housing off.
  6. Optoma HD72 Color Wheel Replacement: step 6, image 1 of 2 Optoma HD72 Color Wheel Replacement: step 6, image 2 of 2
    • Remove the single 2 mm Phillips screw that secures the color wheel.
    • Lift the color wheel up and out of its housing.
  7. Optoma HD72 Color Wheel Replacement: step 7, image 1 of 3 Optoma HD72 Color Wheel Replacement: step 7, image 2 of 3 Optoma HD72 Color Wheel Replacement: step 7, image 3 of 3
    • Remove the single 2 mm Phillips screw that secures the circuit board to the side of the color wheel.
    • Use a sharp tool to cut the zip tie that secures the color wheel’s cables.
    • Remove the color wheel.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 22
All Time: 225
