Optoma HD72 Fan Replacement
  1. Optoma HD72 Fan Replacement, Upper Case: step 1, image 1 of 2 Optoma HD72 Fan Replacement, Upper Case: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
  2. Optoma HD72 Fan Replacement: step 2, image 1 of 1
    • Flip the device over and slightly lift the upper case, with care not to strain the two cables.
    • Disconnect the two cables that connect the top case to the motherboard.
    • Lift the upper case up and off.
  3. Optoma HD72 Fan Replacement, Motherboard: step 3, image 1 of 3 Optoma HD72 Fan Replacement, Motherboard: step 3, image 2 of 3 Optoma HD72 Fan Replacement, Motherboard: step 3, image 3 of 3
    • Disconnect all of the cables that are connected to the motherboard.
  4. Optoma HD72 Fan Replacement: step 4, image 1 of 1
    • Remove the four 2 mm Phillips screws that secure the motherboard.
    • Lift the motherboard up and out of the chassis.
  5. Optoma HD72 Fan Replacement, Fan: step 5, image 1 of 3 Optoma HD72 Fan Replacement, Fan: step 5, image 2 of 3 Optoma HD72 Fan Replacement, Fan: step 5, image 3 of 3
    • Remove the three 2 mm Phillips screws that secure the black housing.
    • Lift the black housing off.
  6. Optoma HD72 Fan Replacement: step 6, image 1 of 3 Optoma HD72 Fan Replacement: step 6, image 2 of 3 Optoma HD72 Fan Replacement: step 6, image 3 of 3
    • Remove the two 2 mm Phillips screws that secure the fan.
    • Lift the fan up and out of the chassis.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 38
All Time: 391
