Optoma HD72 Projection Lamp Replacement
  1. Optoma HD72 Projection Lamp Replacement, Projection Lamp: step 1, image 1 of 1
    • Use a Phillips screwdriver to loosen the single captive 2 mm screw that secures the small lamp panel on the lower case.
    • Remove the panel.
  2. Optoma HD72 Projection Lamp Replacement: step 2, image 1 of 1
    • Use a Phillips screwdriver to loosen the two 2 mm screws on the bottom of the projection lamp housing.
  3. Optoma HD72 Projection Lamp Replacement: step 3, image 1 of 2 Optoma HD72 Projection Lamp Replacement: step 3, image 2 of 2
    • Lift the panel off of the device using the metal handle.
    • Disconnect the pink wires from the black plastic housing.
  4. Optoma HD72 Projection Lamp Replacement: step 4, image 1 of 3 Optoma HD72 Projection Lamp Replacement: step 4, image 2 of 3 Optoma HD72 Projection Lamp Replacement: step 4, image 3 of 3
    • Use a Phillips #2 screwdriver to remove the four 2 mm screws that secure the lamp to its housing.
    • Remove the projection lamp casing by gently lifting the bulb from its housing.
  5. Optoma HD72 Projection Lamp Replacement: step 5, image 1 of 2 Optoma HD72 Projection Lamp Replacement: step 5, image 2 of 2
    • Once the bulb is out, replace it with another bulb and re-secure the housings in reverse order to this guide.
    • The second photo is what the completed bulb housing should look like.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 14
All Time: 149
