Oral-B White Pro 1000 Battery Replacement
Carl Kinsey
Carl Kinsey and 2 other contributors
Last updated on May 27, 2024
25 - 30 minutes
Difficult
Featured Student Guide
Introduction
Go to step 1
Battery Replacement guide for Oral-B White Pro 1000 rechargeable electric toothbrush due to faulty battery. This guide illustrates the disassembly of the Oral-B White Pro 1000 electric toothbrush. Use caution not to short the positive (+) and negative (-) terminals when handling the battery. This guide also requires the use of a soldering tool which reaches high temperatures. Refer to this helpful guide for some soldering and desoldering tips.
  1. Oral-B White Pro 1000 Battery Replacement, Motherboard: step 1, image 1 of 1
    • Remove the brush head by pulling the top away from the base.
  2. Oral-B White Pro 1000 Battery Replacement: step 2, image 1 of 3 Oral-B White Pro 1000 Battery Replacement: step 2, image 2 of 3 Oral-B White Pro 1000 Battery Replacement: step 2, image 3 of 3
    • Pry open the end cap from the toothbrush body.
    • Remove the spring.
  3. Oral-B White Pro 1000 Battery Replacement: step 3, image 1 of 2 Oral-B White Pro 1000 Battery Replacement: step 3, image 2 of 2
    • Apply pressure on the brush shaft to release the toothbrush internals.
    • Remove the internals through the bottom of the toothbrush body.
  4. Oral-B White Pro 1000 Battery Replacement: step 4, image 1 of 2 Oral-B White Pro 1000 Battery Replacement: step 4, image 2 of 2
    • Use flat head screwdriver to remove power button pressure plate.
  5. Oral-B White Pro 1000 Battery Replacement: step 5, image 1 of 3 Oral-B White Pro 1000 Battery Replacement: step 5, image 2 of 3 Oral-B White Pro 1000 Battery Replacement: step 5, image 3 of 3
    • Desolder the coil wire from the motherboard.
    • Check out this helpful guide for some soldering and desoldering tips.
    • Squeeze and remove coil from motherboard.
  6. Oral-B White Pro 1000 Battery Replacement: step 6, image 1 of 2 Oral-B White Pro 1000 Battery Replacement: step 6, image 2 of 2
    • Desolder the motor from motherboard.
    • Remove motherboard and battery from body of toothbrush internals.
  7. Oral-B White Pro 1000 Battery Replacement: step 7, image 1 of 2 Oral-B White Pro 1000 Battery Replacement: step 7, image 2 of 2
    • Desolder the battery connections from the motherboard.
    • Remove motherboard from battery holder.
  8. Oral-B White Pro 1000 Battery Replacement, Battery: step 8, image 1 of 2 Oral-B White Pro 1000 Battery Replacement, Battery: step 8, image 2 of 2
    • Pull to slide battery from battery housing.
    • Remove battery.
23 other people completed this guide.
Carl Kinsey
591 Reputation
1 Guide authored
IUPUI, Team S5-G4, Baechle Fall 2017 Member of IUPUI, Team S5-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G4
3 Members
8 Guides authored
14 Comments
This guide also works for Oral-B genius 9000. Thank You!! On mine, the coil wires was losen. Just soldered it back and works fine again.
polken - Reply
Same with mine: coil was loose. I guessed it because the red blinking light would not react (turn off) by putting the toothbrush on the charger. (checked also a second charger, never through away older parts, using as spare…) ;)
Karsten -
This guide also works for Oral B PRO 2950N. Thank you so much!
I had the same issue, the coil was broken on one side, and it doesn't charge. Adding a little bit of solder to weld the broken end was enough for making it charge again
Jacobo Ventosinos -
What type of battery is that? It's not listed under “parts.”
Andrew Rothman - Reply
I’ve wrote it in another comment as well, but in case you didn’t see it: As far as I know, these are 4/5 AA batteries with about 1200 mAh and U-shaped solder tails. So the size of the battery is roughly 42x14mm . But as mentioned in the comments, regular AA size batteries worked in my case as well, just had to cut the spacers in the battery retainer. AA batteries are cheaper to get obviously and most likely they’ll have more capacity as well.
benn_i -
Past 24 Hours: 37
Past 7 Days: 204
Past 30 Days: 810
All Time: 63,802
