Orbic Wonder Battery Replacement
  1. Orbic Wonder Battery Replacement, Battery: step 1, image 1 of 3 Orbic Wonder Battery Replacement, Battery: step 1, image 2 of 3 Orbic Wonder Battery Replacement, Battery: step 1, image 3 of 3
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
  2. Orbic Wonder Battery Replacement: step 2, image 1 of 3 Orbic Wonder Battery Replacement: step 2, image 2 of 3 Orbic Wonder Battery Replacement: step 2, image 3 of 3
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
  3. Orbic Wonder Battery Replacement: step 3, image 1 of 3 Orbic Wonder Battery Replacement: step 3, image 2 of 3 Orbic Wonder Battery Replacement: step 3, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
  4. Orbic Wonder Battery Replacement: step 4, image 1 of 3 Orbic Wonder Battery Replacement: step 4, image 2 of 3 Orbic Wonder Battery Replacement: step 4, image 3 of 3
    $3.99
    Buy
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
  5. Orbic Wonder Battery Replacement: step 5, image 1 of 3 Orbic Wonder Battery Replacement: step 5, image 2 of 3 Orbic Wonder Battery Replacement: step 5, image 3 of 3
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
2 other people completed this guide.
3 Guide Comments
where do you buy the replacement battery at ?
ricotoomo - Reply Share
Where can I buy a replacement battery
Robert Smith - Share
Thank you big help your smart
gansterms123 - Reply Share
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 51
All Time: 7,974
