Introduction
This guide will walk you through removing all the connections to the motherboard, along with removing the motherboard itself. You will need to use a solder iron in this guide and should handle it with care. There are also small screws that are needed to put the device back together.
Use your thumbs to gently pry the silicon case away from the tablet starting at one of the corners. Once the first corner is separated the other three corners should slip off easily.
Desolder the battery wires from the positive and negative connection to the motherboard. Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
Positive and Negative battery terminals.
Unsolder the positive and negative speaker wires from the connection on the motherboard.
Use the pointed end of a spudger to flip up the black tab connecting the camera's ribbon cable to the motherboard.
Camera ribbon clip.
Unsolder the Wifi wire from the connection on the motherboard.
WiFi terminal
