Oregon Scientific Meep! 4.0 Screen Replacement
  1. Oregon Scientific Meep! 4.0 Screen Replacement, Oregon Scientific Meep! 4.0 Disassembly: step 1, image 1 of 1
    • Use a screwdriver to remove the four 7.0 mm Philips #00 screws from the back of the device.
  2. Oregon Scientific Meep! 4.0 Screen Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to detach the clips on the inside of the device.
  3. Oregon Scientific Meep! 4.0 Screen Replacement, Screen: step 3, image 1 of 1
    • Remove the black tape holding the battery in place.
  4. Oregon Scientific Meep! 4.0 Screen Replacement: step 4, image 1 of 1
    • Use a spudger to separate the battery from its adhesive.
  5. Oregon Scientific Meep! 4.0 Screen Replacement: step 5, image 1 of 1
    • Use a screwdriver to unscrew the three 4.0 mm Philips #00 screws holding the motherboard in place.
  6. Oregon Scientific Meep! 4.0 Screen Replacement: step 6, image 1 of 1
    • Use a plastic opening tool and place the tip in between the white and black pieces holding in the ribbon cable in to release the three ribbon cables around the motherboard.
  7. Oregon Scientific Meep! 4.0 Screen Replacement: step 7, image 1 of 1
    • Remove the motherboard and unscrew the twelve 7.0 Phillips #00 screws holding the metal casing around the screen in.
  8. Oregon Scientific Meep! 4.0 Screen Replacement: step 8, image 1 of 1
    • Use a plastic opening tool to undo the metal clips holding the screen in place.
  9. Oregon Scientific Meep! 4.0 Screen Replacement: step 9, image 1 of 1
    • Remove the plastic over the screen and use a spudger or plastic opening tool to remove the screen from the sticky adhesive.
Lauren Milici
216 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 374
