Oregon Scientific RM318PA Power Switch Replacement
  1. Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: step 1, image 1 of 3 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: step 1, image 2 of 3 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: step 1, image 3 of 3
    • Hold clock so that the clock face is facing away from you.
    • Using your thumbs, push up on the battery cover.
    • Once battery cover is removed, pull down on AC Adapter Jack.
  2. Oregon Scientific RM318PA Power Switch Replacement, Batteries: step 2, image 1 of 1
    • Use one hand to stabilize the clock.
    • Using your other hand, push batteries toward spring and pull out at an angle.
  3. Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: step 3, image 1 of 3 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: step 3, image 2 of 3 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: step 3, image 3 of 3
    • Use a Plastic Opening Tool to pry off the silver casing on the back.
    • Pry at the top of device.
    • Once the back is open at the top, pry at the side of the device closest to the battery compartment.
    • On/Off switch should come off with casing.
  4. Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: step 4, image 1 of 2 Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: step 4, image 2 of 2
    • Insert switch into slot as shown in picture. Push in until you hear a "click."
    • Replace the back of the clock by pressing cover back into place.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 1,387
