Oreva FX-82MS Battery Replacement
  1. Oreva FX-82MS Battery Replacement, Battery: step 1, image 1 of 1
    • Turn off the calculator by pressing the [Shift] button and then press the [AC][OFF] button, (while keeping the [Shift] button pressed down).
  2. Oreva FX-82MS Battery Replacement: step 2, image 1 of 2 Oreva FX-82MS Battery Replacement: step 2, image 2 of 2
    • Flip the calculator over so that the back panel faces up.
    • Use a Phillips #0 screwdriver to remove six, 1.2 mm screws starting from the upper right corner.
  3. Oreva FX-82MS Battery Replacement: step 3, image 1 of 2 Oreva FX-82MS Battery Replacement: step 3, image 2 of 2
    • Remove the back cover and put it to the side.
  4. Oreva FX-82MS Battery Replacement: step 4, image 1 of 2 Oreva FX-82MS Battery Replacement: step 4, image 2 of 2
    • Remove the two old batteries from the slots.
    • Be gentle when removing the batteries to avoid damaging the connectors.
  5. Oreva FX-82MS Battery Replacement: step 5, image 1 of 3 Oreva FX-82MS Battery Replacement: step 5, image 2 of 3 Oreva FX-82MS Battery Replacement: step 5, image 3 of 3
    • Place the two new AAA batteries into the calculator, one by one.
    • Be sure that the direction of the + and - signs on your battery match the signs at the bottom of the battery compartment.
    • Place the case on back of the calculator.
  6. Oreva FX-82MS Battery Replacement: step 6, image 1 of 2 Oreva FX-82MS Battery Replacement: step 6, image 2 of 2
    • Use a Phillips #0 screwdriver to replace the 1.2 mm screws on the back case.
  7. Oreva FX-82MS Battery Replacement: step 7, image 1 of 1
    • Reset the calculator by pressing [ON].
    • Press the [shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3][ALL] button option.
    • Press [=] [yes] button to agree.
    • Press [AC] key to reset.
2 other people completed this guide.
Prarthit patel
196 Reputation
1 Guide authored
One Comment
Half Display Of Oreva Fx-82 MS Scientific calculator Half Display is not showing How to Fix it?
Devanshu Prajapati - Reply
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 38
All Time: 2,706
