Osmo Mobile Handle Disassembly
  1. Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: step 1, image 1 of 2 Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: step 1, image 2 of 2
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Handle Disassembly: step 2, image 1 of 2 Osmo Mobile Handle Disassembly: step 2, image 2 of 2
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Handle Disassembly: step 3, image 1 of 1
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Handle Disassembly: step 4, image 1 of 2 Osmo Mobile Handle Disassembly: step 4, image 2 of 2
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Handle Disassembly: step 5, image 1 of 3 Osmo Mobile Handle Disassembly: step 5, image 2 of 3 Osmo Mobile Handle Disassembly: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Handle Disassembly: step 6, image 1 of 3 Osmo Mobile Handle Disassembly: step 6, image 2 of 3 Osmo Mobile Handle Disassembly: step 6, image 3 of 3
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
3 other people completed this guide.
Ustena Safa
363 Reputation
2 Guides authored
USF Tampa, Team S2-G1, Nance Fall 2017 Member of USF Tampa, Team S2-G1, Nance Fall 2017
USFT-NANCE-F17S2G1
4 Members
12 Guides authored
10 Guide Comments
Bonjour,
La toute première étape est trop vague pouvez-vous donner plus de détails svp.
Je vous remercie d’avance
Guitt97ii - Reply Share
I would not call that a handle disassembly. This instruction takes you up to the things you need to do PRIOR to disassembly.
I can show you the rest in a video format if you’re interested
John M O'Donovan - Reply Share
Could you please show me how to fix the USB port that wenr inside the handle? on my Smove gimbal stabilizer
Juan Carlos Beltran - Share
My osmo has snapped off at the metal camera attachment. Can this be repaired ?
michelle Moore - Reply Share
Your help would be greatly appreciated
Emile Jansen - Share
Past 24 Hours: 3
Past 7 Days: 41
Past 30 Days: 135
All Time: 10,009
