Oster 6329 Outer Shell Removal
  1. Oster 6329 Outer Shell Removal, Outer Shell Removal: step 1, image 1 of 2 Oster 6329 Outer Shell Removal, Outer Shell Removal: step 1, image 2 of 2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Outer Shell Removal: step 2, image 1 of 1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Outer Shell Removal: step 3, image 1 of 1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Outer Shell Removal: step 4, image 1 of 2 Oster 6329 Outer Shell Removal: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Outer Shell Removal: step 5, image 1 of 2 Oster 6329 Outer Shell Removal: step 5, image 2 of 2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
Isaac Williams
237 Reputation
2 Guides authored
Cal Poly, Team 13-15, Regan Winter 2014 Member of Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 45
All Time: 2,467
