Oster 6329 Power Cord Replacement
  1. Oster 6329 Power Cord Replacement, Outer Shell Removal: step 1, image 1 of 2 Oster 6329 Power Cord Replacement, Outer Shell Removal: step 1, image 2 of 2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Power Cord Replacement: step 2, image 1 of 1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Power Cord Replacement: step 3, image 1 of 1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Power Cord Replacement: step 4, image 1 of 2 Oster 6329 Power Cord Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Power Cord Replacement: step 5, image 1 of 2 Oster 6329 Power Cord Replacement: step 5, image 2 of 2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Oster 6329 Power Cord Replacement, Power Cord: step 6, image 1 of 1
    • Using a flat-head screwdriver, pry the power cord from the base of the toaster.
  7. Oster 6329 Power Cord Replacement: step 7, image 1 of 1
    • Using a flat-head screwdriver, pry the white wire from the base.
  8. Oster 6329 Power Cord Replacement: step 8, image 1 of 1
    • Locate the circuit board at the front of the toaster where the power cord and white wire meet.
    • Pull the circuit board up and out to free the circuit board from the body of the toaster.
    • It is tightly fit and may take moderate force to remove.
  9. Oster 6329 Power Cord Replacement: step 9, image 1 of 2 Oster 6329 Power Cord Replacement: step 9, image 2 of 2
    • Desolder the power cord from the circuit board at the locations show in the diagram.
    • For soldering instructions see the iFixit Soldering Guide.
    • The wires should be free from board when un-soldering is complete.
  10. Oster 6329 Power Cord Replacement: step 10, image 1 of 2 Oster 6329 Power Cord Replacement: step 10, image 2 of 2
    • Unscrew the two 1.5cm Phillips-head screws at the back of the toaster that are holding the power cord in place to remove the retaining clip.
    • Remove the plastic retaining clip that is holding the cord in place.
  11. Oster 6329 Power Cord Replacement: step 11, image 1 of 2 Oster 6329 Power Cord Replacement: step 11, image 2 of 2
    • Untie the knot in the power cord.
  12. Oster 6329 Power Cord Replacement: step 12, image 1 of 1
    • Pull the cord from the base to remove the cable.
Timothy Grijalva
234 Reputation
2 Guides authored
Cal Poly, Team 13-15, Regan Winter 2014 Member of Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 896
