Oster BLSTSS-PZO Power Cord Replacement
  1. Oster BLSTSS-PZO  Power Cord Replacement, Circuitboard: step 1, image 1 of 1
    • Use the prying tools to open the four plastic screw holes on the bottom of the blender.
  2. Oster BLSTSS-PZO  Power Cord Replacement: step 2, image 1 of 1
    • Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
  3. Oster BLSTSS-PZO  Power Cord Replacement: step 3, image 1 of 1
    • Gently remove the circuit board.
  4. Oster BLSTSS-PZO  Power Cord Replacement: step 4, image 1 of 2 Oster BLSTSS-PZO  Power Cord Replacement: step 4, image 2 of 2
    • Use the spudger to detach the black wire from the circuit board.
    • Repeat for yellow wire.
  5. Oster BLSTSS-PZO  Power Cord Replacement: step 5, image 1 of 3 Oster BLSTSS-PZO  Power Cord Replacement: step 5, image 2 of 3 Oster BLSTSS-PZO  Power Cord Replacement: step 5, image 3 of 3
    • Use the Phillips #1 to remove the four 8mm screws.
    • Use the medal spudger to detach the circuit board from the buttons.
    • Gently pull and release circuit board from buttons.
  6. Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: step 6, image 1 of 3 Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: step 6, image 2 of 3 Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: step 6, image 3 of 3
    • Locate petal prong on the end of the power cord.
    • Bend metal prong until it's straight with your finger.
  7. Oster BLSTSS-PZO  Power Cord Replacement: step 7, image 1 of 2 Oster BLSTSS-PZO  Power Cord Replacement: step 7, image 2 of 2
    • Spring will pop out when you pull out metal prong
    • Pull prong out of the hole.
  8. Oster BLSTSS-PZO  Power Cord Replacement: step 8, image 1 of 3 Oster BLSTSS-PZO  Power Cord Replacement: step 8, image 2 of 3 Oster BLSTSS-PZO  Power Cord Replacement: step 8, image 3 of 3
    • Pinch plastic prongs on base of blender to remove plastic securing device.
    • Remove plastic securing device.
    • Pull power cord out of blender base.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 210
