Oster BLSTSS-PZO Gear Shaft Replacement
  1. Oster BLSTSS-PZO Gear Shaft Replacement, Circuitboard: step 1, image 1 of 1
    • Use the prying tools to open the four plastic screw holes on the bottom of the blender.
  2. Oster BLSTSS-PZO Gear Shaft Replacement: step 2, image 1 of 1
    • Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
  3. Oster BLSTSS-PZO Gear Shaft Replacement: step 3, image 1 of 1
    • Gently remove the circuit board.
  4. Oster BLSTSS-PZO Gear Shaft Replacement: step 4, image 1 of 2 Oster BLSTSS-PZO Gear Shaft Replacement: step 4, image 2 of 2
    • Use the spudger to detach the black wire from the circuit board.
    • Repeat for yellow wire.
  5. Oster BLSTSS-PZO Gear Shaft Replacement: step 5, image 1 of 3 Oster BLSTSS-PZO Gear Shaft Replacement: step 5, image 2 of 3 Oster BLSTSS-PZO Gear Shaft Replacement: step 5, image 3 of 3
    • Use the Phillips #1 to remove the four 8mm screws.
    • Use the medal spudger to detach the circuit board from the buttons.
    • Gently pull and release circuit board from buttons.
  6. Oster BLSTSS-PZO Gear Shaft Replacement, Gear Shaft: step 6, image 1 of 3 Oster BLSTSS-PZO Gear Shaft Replacement, Gear Shaft: step 6, image 2 of 3 Oster BLSTSS-PZO Gear Shaft Replacement, Gear Shaft: step 6, image 3 of 3
    • Remove the screw on top of the fan with the 4mm socket stock wrench.
    • Remove the fan and washer.
  7. Oster BLSTSS-PZO Gear Shaft Replacement: step 7, image 1 of 3 Oster BLSTSS-PZO Gear Shaft Replacement: step 7, image 2 of 3 Oster BLSTSS-PZO Gear Shaft Replacement: step 7, image 3 of 3
    • Remove the four screws with the 4mm socket stock wrench.
    • Remove gear shaft.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 728
