Oster Blend-N-Go My Blend Blade Assembly Replacement
  1. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: step 1, image 1 of 2 Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: step 1, image 2 of 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Replacement: step 2, image 1 of 3 Oster Blend-N-Go My Blend Blade Assembly Replacement: step 2, image 2 of 3 Oster Blend-N-Go My Blend Blade Assembly Replacement: step 2, image 3 of 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blade Assembly: step 3, image 1 of 1
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
Paul Long
710 Reputation
4 Guides authored
USF Tampa, Team 12-6, Blackwell Fall 2015 Member of USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 Members
5 Guides authored
2 Comments
I’m confused, these are the steps you have to go through every single time you use this blender to blend something. This isn’t really a “replacement” process here. If someone needs to repair a cracked blade assembly or buy a new one, how would they do that?
Alan M - Reply
This process is not helpful at all. I followed as instructed but the blade is not moving at all?! What is going on? Pls provide better HELP INSTRUCTIONS.
Fareda Edwards - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 23
All Time: 3,626
