Oster Blend-N-Go My Blend Blade Assembly Seal Replacement
  1. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: step 1, image 1 of 2 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: step 1, image 2 of 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: step 2, image 1 of 3 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: step 2, image 2 of 3 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: step 2, image 3 of 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly: step 3, image 1 of 1
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly Seal: step 4, image 1 of 1
    • After separating the blade assembly from the blender bottle, position the plastic opening tool on either side of the seal in the blade assembly.
    • Wedge tool between seal and seal seat wall.
  5. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: step 5, image 1 of 1
    • Gently pry the seal up while lifting seal out of the seal seat.
  6. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: step 6, image 1 of 2 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: step 6, image 2 of 2
    • Place and press the new seal into seal seat with finger.
3 other people completed this guide.
Paul Long
710 Reputation
4 Guides authored
USF Tampa, Team 12-6, Blackwell Fall 2015 Member of USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 1,933
